Posted by Bob Kerr on January 04, 2008 at 07:28:54 from (64.12.116.73):
In Reply to: f-12 gas regulator posted by 52 G on January 03, 2008 at 19:26:58:
That little "regulator" on the hood is a primer tank used on kero models. If you run out of fuel while using kero it will not start unless you get it cranked within a min or so. The manifold cools off too much to vaporize the oil. You have to use the drain cock on the carb to drain kero out of it and then he brass nut on top comes off and that is where you put a little gas in to get it restarted. There is no pressure relief on the system since the unused fuel goes back to the fuel lines before the pump. Some "may" go back into the main tank at times, but the rest just circulates through the lines until the carb uses it and the main tank replaces it. It basicly gravity feeds the carb. The lines on my 12 are all there and it works great outside of the leaky needle valve in the carb which floods engine if tank is filled full.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
