Farmall H Hyrdraulics
Posted by TimWafer on January 10, 2008 at 17:49:31 from (170.215.198.98):
Well, I’m finally getting around to restoring my fathers Farmall H. I’ve just begun teardown and am in the parts gathering phase as well. One of the things I’ve always wanted to add to it was live hydraulics. I even went so far as buying a pump a few years ago but that’s as far as I got with that project. Now"s the perfect time to do it. My tractors serial # is FBH364132X which I believe makes it a 1951 model. (Correct me if I’m wrong). Engine # matches the serial #.
It’s been a while since I bought the pump but I recall mention of having to change the front cover and possibly the cam gear to a more robust one as well. Thought I had to change them to ones from a Super H and maybe I should start looking for these parts now. Tonight I pulled the distributor and compared the pump to the front cover and distributor. To my surprise they seem to fit perfectly. Is a 51 model new enough to have the new front cover? How do I tell if I have the stronger cam gear?
I’m not sure who made this pump. It has #’s all over it but wondered if anyone could tell just from this picture. Also missing is the manifold that would bolt to it for the lines to hook into. I suppose I can make one unless someone has an idea where to come up with one. I’m thinking Ill remove the lift-all pump and use that as the hydraulic reservoir. I’m open to advice & suggestions.
Tim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
