Do you have any end play in the steering wheel shaft?? Any end play will result in loose steering. You state the bearing at the end behind the hex plug on the steering grear is good. However, are you sure the plug is in tight. The hex nut on the end of the shaft that holds the bearing in place must tightly clamp the inner race of the bearing against the shoulder on the shaft. The big hex plug must clamp the outer race tightly against the steering box. I found it necessary on occasion to install a machine washer behind the plug to get it to clamp the outer race. If you put a washer there, make sure it does not contact anything but the outer race.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
