Posted by Ted in NE on January 12, 2008 at 15:29:23 from (74.85.105.117):
In Reply to: 656 Hydraulic Pump posted by skyharborcowboy on January 12, 2008 at 10:39:06:
Another cause of air in the hyd system on a 656 is a hole in the return hose from the steering pump oil. This is routed from the top cover down to help super charge the main pump suction tube. Hose can be checked and replaced by removeing the centerlink bracket on the back of the rear frame. Can drain the oil down to inspect or can usually feel the hole in the hose, & replace it. Also while the cover is off take a good look at the bolts that hold the ring gear to the diff.case. These have a habit of breaking off then the bolt comes out and tears of the upper tube the hose goes on, will have a lot of air in the system. I assume you have a clean hyd. filter & good Hy Tran in the rear end, & full to the right level. Ted
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
