Re: Truly Red or Owen Aaland
Posted by Owen Aaland on January 13, 2008 at 16:43:00 from (65.174.247.90):
In Reply to: Truly Red or Owen Aaland posted by Jim Johnson on January 13, 2008 at 05:36:20:
The TA is going bad and you may also have hydraulic problems. The low side of the TA should never allow the transmission to stop. The high side clutch is hydraulically engaged, the low side is a mechanical sprague clutch with hydraulic assist to keep the tractor from free-wheeling when going down hill in low TA. As the sprague wears it gets to the point where it can start to slip. The hydraulic assist on that clutch will help hold things in place so that at first it slips sometimes but still pulls a load most of the time. As the wear continues the frequency of the slipping will increase until it gets to the point where it will not longer pull a load in low TA.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
