Posted by Charlink on January 15, 2008 at 07:55:51 from (207.255.2.2):
Bought a used M off of an advertiser on this site. When I removed the tractor hood, I discovered the nuts for the valve cover were missing. Upon removing the valve cover, I found two valves hung up. One was easy to free up, the other would not free up after several days of soaking in penetrating oil. Removed head, decided to replace all valves as the existing valves had obviously been ground once too often. The engine had been re-sleeved for 4 inch pistons. Decided to glaze bust the sleeves as the cross hatch was gone and some light surface rust was present. After removing pistons, one of the sleeves was protruding about a quarter of an inch above the engine deck. A little wire brushing revealed a letter designation of "D" on three of the cylinders including the one that came out of the block. I can push the sleeve in with my fingers! I know this has been a controversial topic on this board in the past, but is it possible to knurl an engine sleeve in order for it to press firmly into the block??
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
