Posted by Bob Kerr on January 16, 2008 at 22:49:38 from (205.188.116.73):
In Reply to: Locating I.D posted by Dental on January 15, 2008 at 13:37:17:
Should be an alum tag on the firewall under the gas tank. If there is only holes or rivets left, then look on the side of the engine block for a raised pad. There should be engine serial numbers stamped there and they match the tractor serial number. A 29 and newer will have a loop type manifold and an oil filter. The manifold will have a square plate with 2 bolts on the center top and say gasoline on one side and Kerosene on the other. If it doesn;t have that plate it is older than 29 and will run on kero only. (It will run on gas but not well when hot)If it has 3 "gas" caps one is for gasoline, one for kerosene, and one for water which feeds into the engine to keep it from pinging under loads when on kero. Some only have 2 caps for gas and kero.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
