Are you trying to remove the axle or the ifferential shaft?
If the leak is between the final drive and the tanny/diff, you should be able to unbolt the final drive from the tranny (six bolts IIRC) and it should pull right away. The differential shaft will come away with the final drive and you can get at everything to replace the seals as mentioned below.
It will probably help to have the tire, rim and wheel off, and use a sling to hold up the final drive, so you can get to the cover and retainer clip on the outer end.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
