Posted by Dave Allgire on January 21, 2008 at 08:51:58 from (24.217.155.142):
In Reply to: F12 CAMSHAFT posted by kam on January 21, 2008 at 03:08:25:
The correct way is to line up the dot of the camshaft gear with the dot on the crankshaft gear. Those are the factory marks. I don't recall seeing any dots on the mag drive gear. And the service manual says the mag gear does not need to be timed to the camshaft gear. The timing of the mag is adjustable with the two bolts on the magneto coupling. So if you bring #1 cyl. to TDC, then set the mag to fire on #1 by adjustment of the bolts in the mag coupler, the engine should be able to fire from 0 to about 35 degrees ATDC. Hope this helps
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
