I agree with Owen. The main shaft should be shimmed to position the pinion to be properly meshed with the ring gear. The total play (front to back in transmissions with a pinion on the output shaft) is usually zero. If the shaft is located by a combination of the front trans bearing, and the rear trans bearing, and they are tapered roller bearings, they must have a tiny bit of preload to prevent misalignment. If the shaft is positioned using thrust bearings, needle or washer type, the end play should be less than .002". Measured on the ring gear (with a dial indicator perpendicular to the outer edge of a tooth on a tangent line), the backlash is close to .003 to .005". Adjustment of this amount is a combination of the above position of the pinion (forward and back) depth, and the side to side location of the differential. The depth should be set so the pinion teeth have full contact with the length of the ring teeth. The differential position is then set to allow only the above mentioned backlash. The depth gives good tooth contact, the side to side sets backlash. There is dramatically more to working with hypoid gears in a automotive differential because the shafts are not aligned in the horizontal plane. The specifications I have given are experience driven, not from the manual. They are intended to help you understand the issue. Let us know how it is going. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
