With the engine warmed up try this: remove all spark plugs and re-do the compression test only squirt some clean engine oil in each cylinder first, crank the engine to spread the oil around, and repeat the compression test. You did have the throttle wide open to allow maximum air entry, didn't you? If all readings increase 10-2- pounds, this indicates worn rings. With all readings even, the valves are not suspect. To get a more accurate result, purchase a leak-down tester. It will tell you exactly how much leakage your engine has and where it is leaking.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
