Posted by Stan(VA). on January 25, 2008 at 12:44:46 from (208.103.139.255):
In Reply to: 240 engine swap posted by Stones Throw Farm on January 24, 2008 at 15:04:46:
240U owner, Hal & Migraine,
I think the easiest way if he doesn't want to rebuild his block is to look for a 140 or 240 engine, either one should bolt right up.
The issue with the 340 block, I believe is more to do with the back end of the tractor being from the Super H/300/350 line which has a different bellhousing than the Super C/200/230/240/404 line. I'm not aware of any block differences between the Utility/Row crop versions (understanding that the 330/340 are hybrid versions to start with, their blocks definately different than the 300/350's).
The guy with the extra 340 block needs to look for a 330 or 340, poss a 504? And as has been mentioned before, the A/B is not a good idea as they don't have a mount for the hyd pump; the C/Super A/Super C/100/200/130/230 while possible, is not an easy bolt in swap because of the differences up front in the accy's and the radiator connections.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
