One of the studs was rusted nearly through and broke off mine when I was removing it. My radiator guy told be the studs are made onto a larger plate that is riveted and soldered into the bottom tank of the radiator. He said if I wanted he could remover the lower tank, take the plate out, replace the stud and reassemble it all, but it would be expensive.
His alternative repair was to cut the stud off flush, weld a new stud onto a u-shaped bracket shaped to the bottom of the tank and solder it on. I worked fine installed like stock and isn't readily visible from the outside.
Take yours to your radiator guy and I'll bet he has a viable fix.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
