Posted by Daniel H. on January 27, 2008 at 13:46:40 from (66.226.34.159):
In Reply to: 46 super a posted by John OCD on January 27, 2008 at 13:23:05:
Changing them isn't hard, it's getting to them that's the pain. You will have to securely support the rear of the tractor, wedge the front end and remove the final drives. While your in there, plan on changing the differential shaft seals, or your new brakes will be coated with oil before long. I would pick up an I&T manual (IH-8 ) from Tractor Supply or Binder Books, because it has exploded drawings. Also, it is very common for the right brake mounting casting to be worn out, which lets the pedal flop sideways and not pull on the brake. OEM Tractor Parts has new castings, or you can have yours bored out and brass bushing pressed into it by a local machine shop. The shaft may need repair as well. Be careful with the rear end off the ground, I would do one side at a time. See the wedges below Figure 51 A.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
