Posted by Christine Walls on January 28, 2008 at 11:29:08 from (69.19.14.15):
Hello all, I have a Farmall Super H. This summer it started behaving badly, it was running poorly and leaking gas from the bottom of the carb. I put a kit in it and it seemed to help for a while with the leaking, but the tractor did not have its former power and it started leaking again. Then it got to the point where it would not start at all. I've had the carb off and on maybe 5 or six times, adjusting the float and drop levels, and it's still leaking.I think what's going on is the little rod that holds the float is coming out allowing the needle to fall out. I have tried crimping it, but it doesn't work. Has anyone else had this problem and figured out a solution? Also, are the Super H carbs different from standard Hs? I have the books on this tractor and the carbs shown look different than mine. Any help will be most appreciated. Thanks, Chris
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
