The firing order is 1-5-3-6-2-4 if you want to check for plug wire pranksters. Could be kids, neighbors, your brother-in-law, or your coffee shop buddies.
They have this moisture removing spray you can get in a can that may help if there is moisture in the dist. You can check the dist. seal to see if it is ok.
I don't know if this will work, but you might try pulling one plug wire at a time while it is running to see if you can isolate which cylinder is the problem if there is a stuck valve. Then you could squirt some oil in the spark plug hole to lube it. For that matter it might not hurt to pull and check all the plugs and squirt some oil in all the cylinders.
I don't know if a blown intake manifold gasket would do the same thing or not.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
