If you permanently dead ground the gennys FLD post it will always max charge n could overcharge the battery. Keep an eye on the battery for excess outgassing or boiling over acid which could harm it. If the gennys FLD post wires to the 4 position LHBD switch as it should she low charges in L and max charges ONLY if left in the H position (dead grounded FLD). Changin from a mag to a coil ignition doesnt affect if you use a cutout realy and the 4 position ligth switch versus a voltage regulator system other then a coil does take current to operate n is more of a battery load then the mag would have been.
For the genny to work n gthe LHBD switch function the gennys FLD post must ve wired to teh switch and it be good n have a good dash ground
This all depends on how good the battery n genny is n the RPM and the loads (lights n ignition) useage, while a permanent dead grounded FLD is NOT according to Hoyle you may get by with it with no damage, it all depends on battery n genny n the load useage, just be aware of possible overcharging if you run a long long time at full RPM with no lights on.
Gennys ARM post wires to GEN/ARM side of cutout while its FLD wires to LHBD switch and relays BAT side wires to load side of ammeter
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
