Posted by CNKS on February 09, 2008 at 13:42:56 from (216.144.104.128):
In Reply to: My W6 Won't Run posted by TONYR on February 09, 2008 at 13:27:44:
The problem before you worked on the carb was likely a fuel flow problem, perhaps because it ran dry and you stirred up crud when you put gas in the empty tank partially plugging the outlet. A temporary fix, permanent if you're lucky is to run a wire inside the tank into the outlet and dislodge whatever is in there -- may or may not plug again. Also remove the fuel line AND the fitting that screws into the carb, there is a screen inside the fitting. The throttle control problem is probably because the attachment between the carb and the governor (inside the tube between the gov and carb) was not made correctly -- the rod must fit into the notch, hard to see when you are reassembling.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
