the clearance you need is between the crank and the front steering/radiator support. i tried to attatch image with arrow and some coloring. measure all available space you have LxWxH. you should have no problems with hoses, it will be a pump and rigging a good support for it that might be a challenge--it needs to be fairly centered to the crank. the ford setup is nice there's a good hollow space where the IH is solid. there are enough makes of pumps out there that one might work for you after all. then you need to add a reservoir to the loader frame or on the tractor somewhere. that would be the least complicated way to supply oil to the loader. make sure if the loader is disconnected you hook the pump hoses in a loop so it doesn't build pressure or run dry, which means the engine needs to be off for that step.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
