Posted by El Toro on February 11, 2008 at 10:08:00 from (205.188.116.73):
In Reply to: model M with no spark posted by doug gemmell on February 11, 2008 at 08:45:37:
I would clean the points with some 320 wet or dry and then see if it will start. If it still won't start and has no fire. You need to check for battery voltage at the coil with the points open. Should have voltage on both small terminals on the coil. No voltage here check the ignition switch. The feed wire to the switch may be loose, broken or corroded and if there's voltage to the switch and none to the coil when in the on position. Replace the switch. Hal
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
