Re: Where to brace this Farmall 504 axle (pictures)
Posted by mkirsch on February 12, 2008 at 05:49:47 from (64.80.108.53):
In Reply to: Where to brace this Farmall 504 axle (pictures) posted by Tom Graham on February 10, 2008 at 18:48:07:
Charles, a D282 will absolutely tear the transmission and rear end of that tractor up, even if it was an easy swap. If the wheels don't slip, something else will.
Well, it kinda is an easy swap if you don't mind extending the frame rails some. Sounds like that'd be a walk in the park for you, and it probably would look factory by the time you were done...
But, that's adding more weight to the front end, and reducing your practical lifting capacity too. IMHO, 2800lbs is about double what you should be trying to lift with this loader at the absolute maximum.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
