Posted by karl f on February 17, 2008 at 22:57:02 from (172.134.116.228):
In Reply to: worn distributors posted by karl f on February 16, 2008 at 22:31:53:
well, it needs to be rebushed anyway. but between the pertronix and new plugs, cap & rotor there has been no improvement. pretty sure it's fuel. rant: new needle and seat, carb passages poked and bowl gasket, float adjusted, etc. the frequented gas station changed brands and everything from lawnmowers, 4 wheeler, and tractors is having fuel problems of some sort. if you dump the sediment bowl out it will refill and immediately separate into a clear liquid on top and yellow liquid on bottom, with some suspended solids floating around until they settle. sounds a little like it did when the valves were burnt on one cylinder, but without the whistling. seems to have power except it sounds like a deere when you open up the throttle til it catches up, still a slight miss. once in awhile will starve for fuel and die, but never when i'm operating it. tappets are a little loose too, with the colder weather sounds like a JD R diesel, not so clicky but more like diesel knock. problems started when someone siphoned fuel out and it ran out while operating. frustrating when your efforts are for nothing.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
