Posted by bob M on February 18, 2008 at 19:24:00 from (69.205.124.11):
In Reply to: H Hour Meter Install? posted by Clarkbug on February 18, 2008 at 18:58:26:
With coil and distributor ignition connection is a snap. Simply connect the hour meter "-" terminal to the ignition switch (not the distributor) side of the coil primary and ground the meter "+" terminal. (Presumes your H is positive ground. If neg ground reverse the connections at the hour meter.)
A magneto is a bit more complicated. Easiest probably is to install a normally open oil pressure switch (ie. with contacts that CLOSE on pressure rise). Then run a series loop from the battery to the pressure switch to the hour meter and finally to ground. (Observe meter polarity same as above)
Make sure the hour meters are good for 6 volts! (most "universal" hour meters sold now work on 6 - 32 volts)
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
