There is a lot of overkill built into Saginaw -- but your tractor will wear out before it does, and Farmalls are not known to wear out. Overkill because it is listed for the H-450, will work on a 560 and later. A slightly cheaper Saginaw is made for the C, it will fit the others too, uses only one cylinder, I don't know if you can use the original drawbar on it or not, since the C has another type that does not interfere at all with the hitch. As to strength, I have a cheaper no name on my M with very light cat 1 arms, the way I have used it it should have bent by now, but it hasn't. Sounds like the salvage yard ones might work for you. Also Mike at Steel Wheel Ranch sells another brand, I forget what it is. It has its own drawbar, uses one cylinder, considerably cheaper the Saginaw. Worksaver is likely OK, I did not get one for my C because it uses the front arms and a rod, H uses a cylinder.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
