The plow should be level with the furrow wheel in the furrow. If there has been a lot of welding etc on the land axle, you may have a problem. I suspect that the axle was heated to straighten at some point. If so, the metal hardness and rigidity has been damaged. If you can replace the weak axle you will do better. If it is possible to heat and quench the axle several times, the siffness may be regained, however it would have to be removed from the plow. You have to heat it cherry red and quench it quickly in water to restore hardness (several times). As you can see, this is not something you can do with a torch. This is a machine shop job. Heating the steel and then alowing it to air cool with certainly cause soft steel to form.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
