Retcol: Wheel type changed near the end of M production. Before that all H or M rims were drop center, thus the center casting was smaller, clamps or lugs are different from the newer type. I expect those older rims and lugs were made by IH.
Beginning at SH-SM time all Farmall larger than the Super C were equipped with double bead rims and the center cast changed, bit larger diameter.
I've seen different clamps or lugs for the double bead rim type, and yes the outside supplier was the factor that made them different. Once manufacturers went to double bead rims the rims and lugs became standardized. I've used both Cockshutt and Deere rims on later Farmalls. The different outside suppliers is the reason for some differences, however the lugs for double bead rims will all interchange. You can even use a mix of several different types of lugs I've seen.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
