Posted by JimB2 on February 24, 2008 at 13:40:40 from (99.241.179.24):
In Reply to: diff lock stuck posted by more Ron on February 24, 2008 at 09:17:54:
Hi Ron, I saved suggestions by Bernard from Quebec as he has worked on many of these models as a mechanic at CIH. Here is his Diff Lock reply: Differential Lock:
If the differential lock is stuck locked or it doesn't lock. Check the pedal for free movement, it has a shaft that actuates the lock fork, the shaft is below the hitch cover and the link from the pedal hooks on it. Often it has rust on the shaft where it turns in the rear housing. Try to spray a good lube on the shaft or you may have to lift the cover and remove the shaft and clean it. Bernard le mécano Québec Canada
Usually you can release the Diff lock by driving slowly in a straight line, lift up on the foot pedal and tap the left brake pedal then the right brake pedal enough to make the brake grab.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
