Posted by No tools on February 25, 2008 at 18:58:02 from (71.79.47.23):
In Reply to: Trouble 450 clutch posted by james3504 on February 25, 2008 at 17:29:25:
NO 1 Did you align with tool or eye. No 2 you bolted P P and clutch disc tight to flywheel before attaching two halves of tractor together? No 3 if so you have warped the disc. No 4 remove the disc.install another new one. No 5 this time put PP on shaft install disc in front of it. No 6 attach two halves. No 7 you still have the (BATTERY) unhooked coil wire removed. No 8 go up through the bottom of clutch housing opening inspection hole install bolts in PP assembly.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
