Re: Used vegie oil in deisel farmall
Posted by mkirsch on February 28, 2008 at 05:34:20 from (64.80.108.53):
In Reply to: Used vegie oil in deisel farmall posted by Allan In NE on February 27, 2008 at 18:25:08:
gene, clearly you aren't educated on the subject.
SVO, or straight vegetable oil, is different from biodiesel. SVO has no "refinement" done to it, and no special equipment to handle it. All you need is a small hand pump to suck it out of the waste oil barrels at the restaurants, and 5 gallon containers to transport it in.
The vehicle is modified to include a heated (using engine coolant) tank to keep the oil at the right viscosity, and a way to switch from straight diesel to SVO. You can't leave the SVO in the lines or the injector pump, because it will gel up and make a mess!
Sooo, even though a 650 is gas-start, you will still need to have a way to switch to regular diesel at shutdown time before you switch to gas.
Biodiesel is treated chemically with lye and methanol to remove the glycerin, and can be dumped straight into the regular diesel tank.
Either fuel is BETTER for any diesel engine than dino diesel. Both have more lubricity, (they're "more slippery") which reduces wear and tear, makes the engine run smoother, etc..
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
