There are only two places where you can get fuel into the crankcase on the 806. Either it has to come past the shaft seal or from unburned fuel from the injectors. If you got two additional inches in the crankcase in a half hour of running it is highly unlikely that faulty injectors are the problem. You would surely notice poor starting and excessive smoke if they were that bad. That leaves the shaft seal and pump adapter for the leak.
There is no seal inside the pump. The only seal for the fuel is the rear seal in the adapter housing. The side of the seal with the spring in the lip must face the pump. The front seal is installed with the lip forward and it is there to seal oil from getting into the pump. If the front seal were to be installed backwards it is unlikely that oil would actually leak into the pump since the fuel in the pump is under a slight pressure.
It is possible though unlikely that a porous housing is the cause. A defective housing would usually leak long before this. More likely causes would be a damaged seal, a seal installed backwards, a housing damaged when removing the old seal, or damage to the shaft.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
