randy, the top gear is tapered when it drops on the bolster steering shaft. best way i found to remove the shaft, if you have a 2 or 3 jaw puller set it up on the top of the bolster. the jaws are gonna be too big to grab the outside of the gear, but you can catch the the feet on the outside of the bolster. snug the puller up so you put a little tension on the center, i back the nut out but dont remove it yet. take a hammer and hit the gear puller bolt, it should knock the shaft loose out of the gear. once loose, remove nut rest of way. carefull that shaft is heavy. you dont need much tension on the gear puller, just get er good and snug.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
