You might try this. Make sure battery is disconnected and start with removing wires from the main solenoid post. This will be the large threaded post on the solenoid. Losen the nut next to the base of solenoid and turn the threaded post 1/2 turn over. Tighten the base nut back and replace wires and top nut. See if this helps. Remember turn only 1/2 turn or upside down from its orginial postition.
Disconnect battery. Next remove starter and see of the bendix or drive starter turns easily. It should not and you would have a broken bendix.
Hope these two things might help. If not you may have starter problems with brushes or the starter swithch itself.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
