Re: M gas tank
Posted by Patrick Martin on March 09, 2008 at 17:35:09 from (64.154.26.250):
In Reply to: M gas tank posted by Eri k H on March 09, 2008 at 12:13:03:
You can use electrolysis for this also. Use a nail or peice of rebar for the electrode and hang it by the wires into the tank and simply fill the tank to the brim with electrolyte. Be sure to set the tank on a pan or something cause goop bubbles out.
I've got one M tank I'm doing now and when I'm finished I'm going to reverse the process and attempt to re-galvanize the tank. You ought to be able to reverse the polarity and using a chunk of zinc (boat anode, water heater anode) in place of the electrode and coat the inside of the tank with zinc.
This is an experiment I'm in the middle of so I'm not sure but it should work.
If you go with a sealer then the best I've found is made by POR-15. YOU MUST FOLLOW THE DIRECTIONS TO USE IT!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
