Could be a lot of things and I'm certain that you will get lots of good ideas from all of the great guys and gals on this site - one of them will solve your problem.
Before I pulled the carb or bought an expensive kit though, I'd try the easy fixes first. One thing I would check, is if you are getting gas through the line. Plugged lines and rusty tanks are common. Also, if you have the means to do so, check the timing. It might have a plugged jet or port that could be fixed by disconnecting the air cleaner and spraying in some carb cleaner (watch out it will remove paint). If it is lean you would, I think, notice a difference if you let the main jet screw out.
If all the easy stuff fails, you may have to get it on the bench.
Good Luck and tell us what the problem was when you find it.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
