Cam gear sounds most likely or broken cam because a head gasket would not probly blow unless you were pulling it hard.If you take the valve cover off and all the valves are moving it might be the key in the cam gear that broke.You could check your timing and see if both valves on number 1 are closed when the marks for TDC are lined up if not at first turn it around again,if not by then its probly the key broke and gear slipped out of time.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
