Mike - you don't need the generator/VR to run the tractor. (The ignition and the generator/voltage regulator are two completely separate systems that just happen to be connected to the same battery....each operates completely independently of the other.)
To wire the ignition, simply run a wire from the ammeter terminal that's NOT connected to the batterr. Run this wire to either terminal on the ignition switch. Run a 2nd wire from the other ign switch terminal to the coil primary terminal that's NOT connected to the distributor. That's it!
As long as you've got a charged battery the tractor can now be started and run.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
