Posted by Bob M on March 14, 2008 at 10:29:22 from (151.190.254.108):
In Reply to: Super A Crank pulley posted by Hugh MacKay on March 14, 2008 at 08:42:45:
Hi Hugh -
I've never had a Super A apart. However the Super H and M crank pulley hub have a straight (no shoulder/groove) hub sealing surface. I suspect your S/A's pulley hub is similar.
One repair option is to install a speedy sleeve as you suggest.
Another option - depending on the thickness of the replacment seal and if the new one is thinner - is to position the new seal in the front cover so the seal lip rides on an unworn portion of the pulley hub.
I've had good luck with this method on tranny shaft seals on both my Farmalls and my old Minnie-Mo U.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
