Posted by Fromjb2 on March 14, 2008 at 19:34:18 from (99.241.179.24):
In Reply to: 484 Hydaulic Leak posted by Jay in AL on March 13, 2008 at 19:52:55:
Hi Jay, looking at your pictures of the hydraulic control valves, is the leak coming from the pressure relief valve (the tubular cylinder with the nut that screws onto the body of the control valve)? If it is you can try tightening the nut some. Be careful if you try to remove this relief valve as it is under spring tension. It is common for hydraulic hoses to spring a leak after years of use and damage to the outside by rubbing on metal parts. Split an old heater hose to put over hydraulic hose anywhere there is abrasion.
Hopefully there is not a piece of hydraulic hose floating around in your hydraulic system. My brother had a strip of rubber about an inch long in his loader hydraulics once.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
