S/Ns for M cutovers to newer parts
Posted by Dan Bear Kelley on March 16, 2008 at 11:51:36 from (206.53.20.159):
Does anyone know at what S/N International changed the front cover bolting patterns for the distributor adapter? Hmmm. Maybe I should elaborate a little more. I've got a 1951 M:
  1. I've heard that for very late M's, a SM live hydraulic pump will bolt right up.
  2. I've heard that for early M's, a SM live hydraulic pump will NOT bolt up.
  3. So, at what S/N did International make the change?
  4. I've heard that it's easy to fill the old hole, and redrill and tap a new hole, to put a SM pump on an earlier M.
  5. I've heard that the best course of action is to replace the front plate to get the SM bolt pattern on an M.
  6. (Opinion) Is the first option really as cheesy as it sounds?
  7. I've heard that a specially hardened cam gear is needed for the SM pump, so as not to strip the timing gears.
  8. I've heard of people going for years with the old (less hardened) cam gear without problems. (Probably not in my case with a front loader)
  9. I've heard that the newer hardened gear was actually in later M's after a specific S/N.
  10. So, at what S/N did International make the change to the cam gear?
Does that seem to cover all the bases? I know I'm forgetting something.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
