Hi Clark, you are correct there is a flow divider in the MCV valve that splits the 9 GPM output of the hydraulic pump into 3 GPM for PS and PB and 6 GPM for 3pt and remotes. The brakes are supplied by hydraulic oil from the return side of the hydraulic oil cooler in front of the rad. The brakes are also a dead end circuit so any air that gets in the brake system stays there until the brakes are bled. Re your problem, try activating the remote control valve until your hear the relief valve squeal. Sometimes this will dislodge dirt stuck in one of the MCV valves. If the above dosen't cure the problem then it is time for diagnostics with hydraulic flow and pressure guages to determine if it is a weak pump or MCV valve problem.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
