Posted by Janicholson on March 22, 2008 at 13:24:25 from (199.17.6.122):
In Reply to: Is this wrong posted by Vito on March 22, 2008 at 13:06:34:
Yes it is wrong. But understandable!!! All three connections on the H are hooked up to the same port on the pump. The left rear is designed to have a restrictor in it to limit the response of a trailing implement cylinder, but (I think)it needs a restrictor in the elbo to do that. There is no way to get multiple supply from the different ports. When connected to a two way valve, the valve goes to open center and thus dumps all pressure. Connect a second (or third) valve to the system such that the return (exhaust) from one feeds the intake of the next. Do not use two valves at once, or unpredictable motion happens with this setup. A open center dual valve system will be setup this way. JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
