Posted by Randy-IA on March 22, 2008 at 19:07:07 from (207.177.83.88):
Hi All , The transmission rebuild has moved to the final drive too . I'll probably have to replace the differential and axle bearings because of the crud that was in the oil . I might take the cheapskate way out for the the axle and bullgear pinion bearings and take them out of a parts tractor instead of buying new ones . I don't know yet till I get everything apart . I have a question about the reverse idler shaft . It has pits in it from rust . It only had minor play in the old bushings but I bought new bushings anyway ( Sticker Shock !! ) . I wasn't surprised at the cost of the bearings but the bushings I was ! The shaft was plugged with crud and I got it cleaned out as good as I can . I'm thinking of soaking it in carb cleaner overnight to be sure it's clean on the inside . I'm not to concerned about the rust pits . I feel that they will just hold that much more oil for lubrication . I was curious as to what everybody else thought about it ? I've shined it up with emery cloth . I still have to check the clearance of the new bushings . Hopefully it'll be snug without needing honing or to loose . One more question about the clutch throw out bearing . This one is tight . So is it OK to wash it off in a parts washer with commercial cleaner ? I'm not sure if it has any rubber seals in it I need to be concerned about . I haven't decided yet whether or not I'm replacing the clutch parts . I don't want to split the tractor to remove the flywheel to turn it and it needs turning if I put in a new disc . It has it's fair share of heat cracks . Thanks to all for any opinions ! ...Randy
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
