The 2 prong switch is used on tractors with a distributor ignition, a Magneto uses a 1 prong switch that grounds the magneto terminal when you push in the switch which stops the engine. You can use a 2 prong switch on a magneto if you take one terminal and wire it to ground, but you need to pull out the switch to stop the engine and push it in to run the engine. If you want your restoration to be original, use a 2 prong switch on a distributor ignition or a 1 prong switch on a magneto ignition.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
