I've been fighting about the same thing with my 2606. You can see a lot of my threads on it if you search 2606 or 606 or 2656. Took me a while to figure out what I had. The parts guys in Hutch have been very helpful to me.
Your 560 doesn't have the hand pump like mine. I looked at the picture in the book for yours but I'm not sure I understand it. My main problem turned out to be a piece of metal under the ball of the bypass in the draft control housing.
Are your hydraulics whining or squealing which might be indicative of fluid squeezing through a bypass?
One way to see if the steering cylinder is leaking internally by the seal is to turn it all the way in one direction. Then disconnect the opposite line and keep trying to turn it in that direction. If it is not leaking then nothing will come out.
While you are at it, turn it back the other way to see what kind of flow you are getting. When mine was bypassing, it just kinda spit out some fluid with hardly no psi. Then reattach the line, turn the wheels the other way and remove the other line and do the same test.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
