First, I'd get both wheels filled with the same amount of fluid and filled to the maximum.
The further out you hang the weight, the less weight you'll need, but then you compromise maneuverability. That blade will get in the way in tight spaces.
What I've seen used most commonly is a simple mass of concrete connected to the 3pt hitch. You get a 55gal drum, shove a 1-1/8" steel bar through the middle, and fill it with Sakrete and rocks. Sometimes I've even seen them cast into large blocks instead of cylinders, even.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
