7100 series Magnums had issues with flow controls, check and see if set screw has came out where flow control cable meets the flow control. Manually turn stem of flow control while under unit it is probably stuck in brass packing nut. Be carefull this can get expensive if you get to rough with flow control. Case does offer a replacement flow control and spool if you break it for about 400 dollars. Good Luck
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
