Posted by Steven f/AZ on March 27, 2008 at 07:15:42 from (216.67.213.217):
In Reply to: Farmall 300 hydraulics posted by Dick fm Iowa on March 26, 2008 at 14:49:24:
If the pump is working/pumping fluid, you should hear a bit of whine from it. Also, you should be able to put your hands on the lines to and from the pump and "feel" the fluid going through.
If you don't have cylinders hooked up to the remotes, the engine should pull down a bit when you cycle them...
Another idea if you don't have cylinders - take a hose and make a loop from one outlet to the other on a remote so the fluid can just make the loop through.
I have a feeling that fluid at the priming plug doesn't necessarily mean the pump is working... did you try a bit of pressure in the reservoir? Needs to be running when you pressurize so the pump sucks the oil.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
