Posted by LN on March 29, 2008 at 07:16:53 from (66.133.174.249):
In Reply to: Welding cast iron posted by STEWARTINPA on March 29, 2008 at 02:06:23:
another option on flat surfaces with cracks is to( dry stitch) them any good machine shop can do this or sell you the kit to do it . To do this you drill holes in the crack, tap it out then wind the special cast iron stitch plug in, drill another hole repeat process over and over till crack is repaired then peen the plugs to have a repair that will hold forever without the heat of welding have had good success doing this with several cylinder blocks and a couple of heads may work with your pan
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
