Posted by John T on March 29, 2008 at 20:46:29 from (66.244.97.31):
In Reply to: 10 ohm resister posted by 160dan on March 29, 2008 at 19:49:35:
An ohm meter will tell what it is, good chance its a diode or maybe an in line resistor. Ohm it out real quick n you will have the answer. It would wire somewhere between the coils high input terminal or the ign switches IGN output terminal and the lil No 1 side alternator terminal...Ignition ballast resistors are also used when its a 12 volt tractor with a 6 volt coil, they are around 1 to 2 ohms or so. An idiot light could also be used for the alternators excitation instead of a resisotr or diode.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
