Here's a backside view of a switch as on your B. The field resistor is the wirewound unit at the bottom. Seems to me the correct resistance is 3 or 4 ohms - however I'm only going from memory here...
However if it were mine I'd replace the cutout relay with a voltage regulator. The V/R will do a much better job of maintaining the battery, and it will eliminate the need for the field resistor.
I believe the fuse is an SFE 10 (glass tube type, 10 amp). However later letter series and Supers used an SFE 20 (20 amp) fuse - that's what I recommend.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
